Lenovo ThinkPad T495 Speaker Replacement
  1. Lenovo ThinkPad T495 Speaker Replacement, Baseplate: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Speaker Replacement: step 2, image 1 of 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Speaker Replacement, Speaker: step 3, image 1 of 3 Lenovo ThinkPad T495 Speaker Replacement, Speaker: step 3, image 2 of 3 Lenovo ThinkPad T495 Speaker Replacement, Speaker: step 3, image 3 of 3
    • Grip the speaker cable as close as possible to its motherboard plug, and pull directly backwards, parallel to the motherboard, until the plug releases.
  4. Lenovo ThinkPad T495 Speaker Replacement: step 4, image 1 of 2 Lenovo ThinkPad T495 Speaker Replacement: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three 1.6 mm screws.
    • Holding both sides, lift the speaker up and out.
Christian Taylor
523 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 35
All Time: 474
