Lenovo ThinkPad T560 Fan Replacement
  1. Lenovo ThinkPad T560 Fan Replacement, Back Panel: step 1, image 1 of 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Fan Replacement: step 2, image 1 of 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Fan Replacement, Battery: step 3, image 1 of 2 Lenovo ThinkPad T560 Fan Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Fan Replacement: step 4, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
  5. Lenovo ThinkPad T560 Fan Replacement, Fan: step 5, image 1 of 3 Lenovo ThinkPad T560 Fan Replacement, Fan: step 5, image 2 of 3 Lenovo ThinkPad T560 Fan Replacement, Fan: step 5, image 3 of 3
    • Using the iFixit opening tool, unlatch the power button's connection to the motherboard.
    • Remove the ribbon cable from the connector.
  6. Lenovo ThinkPad T560 Fan Replacement: step 6, image 1 of 1
    • Unplug the fan from the motherboard.
  7. Lenovo ThinkPad T560 Fan Replacement: step 7, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the four 3.5 mm screws securing the heatsink.
  8. Lenovo ThinkPad T560 Fan Replacement: step 8, image 1 of 1
    • Using the Phillips #0 screwdriver, unscrew the 3.5mm screw securing the fan to the case.
    • Remove the fan and conjoined heatsink.
Jackson Reynolds
517 Reputation
5 Guides authored
Clemson, Team 1-3, Hunter Spring 2022 Member of Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 789
