Lenovo ThinkPad T560 Keyboard Replacement
  1. Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • Using the spudger, slide the keyboard up towards the display at the notches created for this purpose.
  2. Lenovo ThinkPad T560 Keyboard Replacement: step 2, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the six 3.5 mm screws that secure the keyboard to the laptop.
  3. Lenovo ThinkPad T560 Keyboard Replacement: step 3, image 1 of 2 Lenovo ThinkPad T560 Keyboard Replacement: step 3, image 2 of 2
    • Using the spudger, push the keyboard toward the display and then slide it back out of the connector at top of the keyboard to remove.
    • Don't pull on the keyboard as it is attached by two ZIF connectors underneath.
    • Flip the keyboard over to expose the keyboard's connections to the motherboard and touchpad.
  4. Lenovo ThinkPad T560 Keyboard Replacement: step 4, image 1 of 2 Lenovo ThinkPad T560 Keyboard Replacement: step 4, image 2 of 2
    • Using the spudger, open the latches securing the keyboard's connections to the motherboard and touchpad.
    • Remove the keyboard.
Jackson Reynolds
517 Reputation
5 Guides authored
Clemson, Team 1-3, Hunter Spring 2022 Member of Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 72
All Time: 2,156
