Lenovo ThinkPad T560 SSD/Hard Drive Replacement
  1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: step 2, image 1 of 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: step 3, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
  4. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: step 4, image 1 of 1
    • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
  5. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: step 5, image 1 of 1
    • Remove SSD/Hard Drive case from the drive.
2 other people completed this guide.
Jackson Reynolds
517 Reputation
5 Guides authored
Clemson, Team 1-3, Hunter Spring 2022 Member of Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 160
All Time: 4,162
