Lenovo ThinkPad T580 Hard Drive Replacement
  1. Lenovo ThinkPad T580 Hard Drive Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T580 Hard Drive Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T580 Hard Drive Replacement, External Battery: step 1, image 3 of 3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Hard Drive Replacement: step 2, image 1 of 3 Lenovo ThinkPad T580 Hard Drive Replacement: step 2, image 2 of 3 Lenovo ThinkPad T580 Hard Drive Replacement: step 2, image 3 of 3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Hard Drive Replacement: step 3, image 1 of 3 Lenovo ThinkPad T580 Hard Drive Replacement: step 3, image 2 of 3 Lenovo ThinkPad T580 Hard Drive Replacement: step 3, image 3 of 3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Hard Drive Replacement, Bottom Case: step 4, image 1 of 2 Lenovo ThinkPad T580 Hard Drive Replacement, Bottom Case: step 4, image 2 of 2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Hard Drive Replacement: step 5, image 1 of 3 Lenovo ThinkPad T580 Hard Drive Replacement: step 5, image 2 of 3 Lenovo ThinkPad T580 Hard Drive Replacement: step 5, image 3 of 3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Hard Drive Replacement: step 6, image 1 of 3 Lenovo ThinkPad T580 Hard Drive Replacement: step 6, image 2 of 3 Lenovo ThinkPad T580 Hard Drive Replacement: step 6, image 3 of 3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Hard Drive Replacement, Hard Drive: step 7, image 1 of 2 Lenovo ThinkPad T580 Hard Drive Replacement, Hard Drive: step 7, image 2 of 2
    • Using a spudger, flip up the locking black tab of the hard drive ZIF connector.
    • Pull the hard drive cable out from the connector on the motherboard.
  8. Lenovo ThinkPad T580 Hard Drive Replacement: step 8, image 1 of 1
    • Pull the hard drive case out of the slot using the tab.
2 other people completed this guide.
Ben Elkayam
978 Reputation
8 Guides authored
Cal Poly, Team S18-G6, White Winter 2020 Member of Cal Poly, Team S18-G6, White Winter 2020
CPSU-WHITE-W20S18G6
4 Members
24 Guides authored
One Comment
Before any of this go into the bios setup and disable the internal battery.
Roger Elder - Reply
Past 24 Hours: 4
Past 7 Days: 50
Past 30 Days: 272
All Time: 8,973
