Lenovo ThinkPad T580 RAM Replacement
  1. Lenovo ThinkPad T580 RAM Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement, External Battery: step 1, image 3 of 3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 2, image 3 of 3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 RAM Replacement: step 3, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 3, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 3, image 3 of 3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 RAM Replacement, Bottom Case: step 4, image 1 of 2 Lenovo ThinkPad T580 RAM Replacement, Bottom Case: step 4, image 2 of 2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 RAM Replacement: step 5, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 5, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 5, image 3 of 3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 RAM Replacement: step 6, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 6, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 6, image 3 of 3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 RAM Replacement, Internal Battery: step 7, image 1 of 1
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 RAM Replacement: step 8, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 8, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 8, image 3 of 3
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 RAM Replacement, RAM: step 9, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement, RAM: step 9, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement, RAM: step 9, image 3 of 3
    • Pull the two tabs on either side of the RAM card outwards with your fingers.
  10. Lenovo ThinkPad T580 RAM Replacement: step 10, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 10, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 10, image 3 of 3
    • The RAM module should pop up to rest at an angle to the motherboard.
    • Pull the Wi-Fi card out from the port by the edges of the card.
    • Try to remove and insert the card at the same angle at which it rests with respect to the motherboard.
  11. Lenovo ThinkPad T580 RAM Replacement: step 11, image 1 of 2 Lenovo ThinkPad T580 RAM Replacement: step 11, image 2 of 2
    • Remove the RAM module from the laptop.
    • Repeat the same process for the second RAM module if your computer included one.
Austin Blakely
19,955 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,074 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 26
All Time: 1,275
