Lenovo ThinkPad W540 Display Replacement
Kevin Dang
Kevin Dang and 2 other contributors
Last updated on April 23, 2024
10 minutes
Moderate
Introduction
Go to step 1
If your Lenovo ThinkPad W540 has a black, distorted, or a physically cracked screen, this guide should help you replace the display itself. Displays are important as they obviously show you what you are currently doing with the laptop. A faulty display will lead to a poor user experience to the user.
Note that this guide assumes that you have already checked that your video drivers are ok, and the display brightness is not on the lowest setting.
Parts
Tools
Show more…
  1. Lenovo ThinkPad W540 Display Replacement, Display: step 1, image 1 of 2 Lenovo ThinkPad W540 Display Replacement, Display: step 1, image 2 of 2
    • Open your laptop so that the screen is at around a 180 degree angle.
    • Using a plastic opening tool, pry open the outer frame of the display.
    • Generally, it is best practice to start from the corner first, and then guide the opening tool around the the frame.
  2. Lenovo ThinkPad W540 Display Replacement: step 2, image 1 of 2 Lenovo ThinkPad W540 Display Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to unscrew the four 3 mm screws holding the display, one for each corner.
    • Once unscrewed, flip the display over the other side of the laptop (keyboard end).
  3. Lenovo ThinkPad W540 Display Replacement: step 3, image 1 of 2 Lenovo ThinkPad W540 Display Replacement: step 3, image 2 of 2
    • Use a plastic spudger, safety lift the adhesive tape from the connector.
    • Do not disregard the tape from the connector entirely as you will be reusing it later.
    • This adhesive tape will be strong, remove the tape carefully to prevent damage to the display connector.
  4. Lenovo ThinkPad W540 Display Replacement: step 4, image 1 of 1
    • Safely disconnect the display from the connector.
    • Although you can use your hands to disconnect the connector, it is recommended that you use a spudger instead.
2 other people completed this guide.
Kevin Dang
360 Reputation
2 Guides authored
UMass Dartmouth, Team 3-2, Konn Fall 2023 Member of UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 12
Past 30 Days: 29
All Time: 345
