Lenovo ThinkPad W540 Hard Drive Replacement
  1. Lenovo ThinkPad W540 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Lenovo ThinkPad W540 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Flip the laptop to the bottom so the backplate is shown.
    • Use a Phillips #0 screwdriver to unscrew the 2 captive screws that secure the backplate.
    • These screws should hold on to the backplate even after removal. So, you shouldn't worry about losing them.
  2. Lenovo ThinkPad W540 Hard Drive Replacement: step 2, image 1 of 2 Lenovo ThinkPad W540 Hard Drive Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to unscrew the single 3 mm screw that secures the hard drive.
  3. Lenovo ThinkPad W540 Hard Drive Replacement: step 3, image 1 of 1
    • Lift up the bottom half of the hard drive at a 25 degree angle.
    • Simply pull out the hard drive.
  4. Lenovo ThinkPad W540 Hard Drive Replacement: step 4, image 1 of 3 Lenovo ThinkPad W540 Hard Drive Replacement: step 4, image 2 of 3 Lenovo ThinkPad W540 Hard Drive Replacement: step 4, image 3 of 3
    • Safely remove the plastic guard surrounding both the hard drive and ESD shielding.
  5. Lenovo ThinkPad W540 Hard Drive Replacement: step 5, image 1 of 2 Lenovo ThinkPad W540 Hard Drive Replacement: step 5, image 2 of 2
    • Carefully removing the ESD shielding surrounding the hard drive.
    • Do not disregard the ESD shielding unless your new hard drive or SSD comes with its own shielding. Failure to do so will lead to severe damage to your device.
Kevin Dang
360 Reputation
2 Guides authored
UMass Dartmouth, Team 3-2, Konn Fall 2023 Member of UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 27
All Time: 500
