Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): step 1, image 1 of 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): step 1, image 2 of 2
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: step 2, image 1 of 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: step 2, image 2 of 2
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: step 3, image 1 of 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: step 3, image 2 of 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: step 3, image 3 of 3
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: step 4, image 1 of 1
    • Once the ODD has popped out, simply grab and pull out the drive bay.
Isaac
205 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 101
