Lenovo ThinkPad W540 RAM Replacement
Nana A
Nana A and 2 other contributors
Last updated on January 2, 2024
5 minutes
Easy
Introduction
Go to step 1
If your programs began to slow down your laptop, or programs continue to hang under load, then this guide should help you replace the RAM/Memory stick within your laptop. This guide is also helpful in the case that you need to upgrade your laptop's RAM sticks.
Tools
  1. Lenovo ThinkPad W540 RAM Replacement, RAM: step 1, image 1 of 2 Lenovo ThinkPad W540 RAM Replacement, RAM: step 1, image 2 of 2
    • Flip your laptop to the bottom so that the backplate is shown.
    • Unscrew the captive screws on the backplate with a Phillips #0 screwdriver.
    • The screws should hold to the backplate so you shouldn’t worry about losing them.
  2. Lenovo ThinkPad W540 RAM Replacement: step 2, image 1 of 2 Lenovo ThinkPad W540 RAM Replacement: step 2, image 2 of 2
    • Locate the two latches that hold the RAM stick into the laptop, and push them away from the stick.
    • After pushing on the latches, the RAM stick should lift up at an angle.
  3. Lenovo ThinkPad W540 RAM Replacement: step 3, image 1 of 1
    • Safely push forward the RAM stick away from the slot, and remove the stick entirely.
Nana A
97 Reputation
1 Guide authored
UMass Dartmouth, Team 3-2, Konn Fall 2023 Member of UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 218
