Lenovo ThinkPad W540 Wi-Fi Card Replacement
  1. Lenovo ThinkPad W540 Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 2 Lenovo ThinkPad W540 Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 2 of 2
    • Use a Phillips #0 screwdriver to unscrew the captive screw that secures the Wi-Fi card compartment plate.
    • The screw that holds on to the WiFi card compartment plate should hold on to the plate itself. So you shouldn't worry about losing it
    • Note the position of the gray and black cables on the Wi-Fi card.
  2. Lenovo ThinkPad W540 Wi-Fi Card Replacement: step 2, image 1 of 3 Lenovo ThinkPad W540 Wi-Fi Card Replacement: step 2, image 2 of 3 Lenovo ThinkPad W540 Wi-Fi Card Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Using your Tweezers start with either of the gray or black cables and carefully dislodge them
  3. Lenovo ThinkPad W540 Wi-Fi Card Replacement: step 3, image 1 of 2 Lenovo ThinkPad W540 Wi-Fi Card Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the 3 mm screw that fastens the Wi-Fi card.
  4. Lenovo ThinkPad W540 Wi-Fi Card Replacement: step 4, image 1 of 2 Lenovo ThinkPad W540 Wi-Fi Card Replacement: step 4, image 2 of 2
    • Using your hand or a capable device, carefully detach the Wi-Fi card.
Bryan O
109 Reputation
1 Guide authored
UMass Dartmouth, Team 3-2, Konn Fall 2023 Member of UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 113
