Lenovo ThinkPad W541 Touchpad Replacement
  1. Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: step 1, image 1 of 2 Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: step 1, image 2 of 2
    • Slide the clips to the left and right sides, remove the battery upwards.
    • Loosen two Phillips #00 screws and open the cover plate.
    • Remove four 9.0 mm Phillips #00 case screws.
    • Remove three 9.0 mm Phillips #00 screws circled with red in the second picture.
  2. Lenovo ThinkPad W541 Touchpad Replacement: step 2, image 1 of 3 Lenovo ThinkPad W541 Touchpad Replacement: step 2, image 2 of 3 Lenovo ThinkPad W541 Touchpad Replacement: step 2, image 3 of 3
    • Use the pry bar to push the keypad below the slot shown in the first picture and push it upward.
    • Loosen six Phillips #000 screws circled with red in the second picture, lift up the keyboard.
  3. Lenovo ThinkPad W541 Touchpad Replacement: step 3, image 1 of 3 Lenovo ThinkPad W541 Touchpad Replacement: step 3, image 2 of 3 Lenovo ThinkPad W541 Touchpad Replacement: step 3, image 3 of 3
    • Open the black clips according to the direction marked in the first picture and remove the cable.
    • Use a pry bar to pry open the black protective casing upwards.
    • Follow the direction shown in the third picture, open the black clips upwards and remove the cable.
  4. Lenovo ThinkPad W541 Touchpad Replacement: step 4, image 1 of 3 Lenovo ThinkPad W541 Touchpad Replacement: step 4, image 2 of 3 Lenovo ThinkPad W541 Touchpad Replacement: step 4, image 3 of 3
    • Remove the four 2.0 mm Phillips #000 screws circled with red in the first picture.
    • Carefully remove the metal tape shown in the second picture and paste it back on after replacing the new touchpad.
    • As shown in the third picture, remove the trackpad that needs to be replaced.
  5. Lenovo ThinkPad W541 Touchpad Replacement: step 5, image 1 of 1
    • You can replace your touchpad with a new one. To install your computer just follow this guide in reverse.
Panaien Liu
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 395
