Lenovo ThinkPad W550S BIOS Battery Replacement
  1. Lenovo ThinkPad W550S BIOS Battery Replacement, Open the case: step 1, image 1 of 1
    • Make sure the laptop is off and remove the battery.
    • Loosen all screws (these remain in the case bottom) with a PH 00 screwdriver.
    • Open the clips around the case with an iFixit opening tool.
  2. Lenovo ThinkPad W550S BIOS Battery Replacement, Opening the case: step 2, image 1 of 1
    • To remove the case bottom, you have to lift it slightly and push it backwards.
    • Be careful not to damage the case!
  3. Lenovo ThinkPad W550S BIOS Battery Replacement, Remove battery: step 3, image 1 of 1
    • Carefully remove the foil
    • Disconnect the plug of the battery.
    • Remove the battery from the circuit board. This is glued to the circuit board with a spacer.
  4. Lenovo ThinkPad W550S BIOS Battery Replacement, Replace battery: step 4, image 1 of 1
    • Find a replacement battery based on the type designation (in my case a 08K8050 - CR 2032 3V) and insert it.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Michael
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,129
