Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement
Vanessa Garcia Sanchez
Vanessa Garcia Sanchez and 2 other contributors
Last updated on June 10, 2020
5 - 10 minutes
Easy
Introduction
Go to step 1
If your Lenovo ThinkPad X1 Carbon (2nd Gen) randomly shuts off after getting hot, use this guide to replace the fan.
The fan cools down the computer and prevents the computer from overheating.
Before using this guide, check to make sure that nothing is covering the fan. The blocked fan may be the reason the computer is overheating. Also, use a dust removal spray to carefully clean out the vent. The cause of overheating may be the dust blocking the computer’s air flow. Cleaning the vent can prevent the need of replacing the fan.
Before you begin, make sure your computer is off.
Tools
Show more…
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Back Cover: step 1, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: step 2, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: step 2, image 2 of 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Battery: step 3, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Battery: step 3, image 2 of 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: step 4, image 1 of 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: step 5, image 1 of 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Fan: step 6, image 1 of 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: step 7, image 1 of 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: step 8, image 1 of 1
    • Remove the fan by lifting it directly up.
2 other people completed this guide.
127 Reputation
1 Guide authored
Cal Poly, Team S18-G4, White Winter 2020 Member of Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 29
All Time: 1,285
