You're viewing a previously published version of this guide.  View latest version
Older Newer
Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
Eevee Murdock
Eevee Murdock and 2 other contributors
Last updated on June 10, 2020
15 - 45 minutes
Moderate
Introduction
Go to step 1
If your Lenovo ThinkPad X1 Carbon (2nd Gen) charger will not work, the screen randomly turns blue, or the laptop randomly freezes, use this guide to replace the motherboard.
The motherboard allows all of the components of your computer to communicate with each other.
Before using this guide, if the charger will not work, try using a few different outlets to charge your computer and check that your battery firmware is updated.
Also, try turning it completely off and on again.
Before you begin, make sure your computer is off.
Tools
Show more…
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: step 1, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 2, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 2, image 2 of 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: step 3, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: step 3, image 2 of 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 4, image 1 of 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 5, image 1 of 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: step 6, image 1 of 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 7, image 1 of 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 8, image 1 of 1
    • Remove the fan by lifting it directly up.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: step 9, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: step 9, image 2 of 2
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 10, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 10, image 2 of 2
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 11, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 12, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 13, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 13, image 2 of 2
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 14, image 1 of 1
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 15, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 15, image 2 of 2
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 16, image 1 of 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: step 16, image 2 of 2
    • Carefully remove the motherboard by lifting it and pulling towards the left.
Eevee Murdock
1,110 Reputation
6 Guides authored
Cal Poly, Team S18-G4, White Winter 2020 Member of Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Members
9 Guides authored
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 64
All Time: 4,121
