Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement
  1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: step 1, image 1 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: step 1, image 2 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: step 1, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: step 2, image 1 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: step 2, image 2 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
    • Lift the copper plate up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement: step 3, image 1 of 1
    • Gently lift up on the left side of the SSD, then pull it to the left to remove it from its socket.
0 Comments
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 71
All Time: 1,673
