Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: step 1, image 1 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: step 1, image 2 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: step 1, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: step 2, image 1 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: step 2, image 2 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: step 3, image 1 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: step 3, image 2 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: step 3, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
  4. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: step 4, image 1 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: step 4, image 2 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: step 4, image 3 of 3
    • Use the spudger to lift the flap covering the speaker wire.
    • Starting at the top of the right speaker, follow the wire connected to the top of the left speaker. Use the tip of a spudger to free the wire from the plastic brackets it lies under.
    • Starting from near the bottom-left side of the right speaker, follow the lower wire, unseating the speaker cable as you go.
  5. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: step 5, image 1 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: step 5, image 2 of 3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: step 5, image 3 of 3
    • Place your fingernails behind each of the plastic tabs on the speaker's plug and pull directly backwards until the plug releases from its port.
    • Lift the speakers up and out.
0 Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 28
All Time: 544
