Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement
Katrina Lee
Katrina Lee and 5 other contributors
Last updated on May 16, 2024
10 minutes
Easy
Needs Better Images
Introduction
Go to step 1
Before using this guide, check if your pen is inserted in the charging slot correctly or if it is chipped or damaged near the charging connector. You may also follow the guide through Step 3 to ensure that the charging wire has not been disconnected from the port on the circuit board. If it is, reconnect the wire and test the charging port.
If you have determined that the charging port is damaged or no longer charges the pen, replace the charging port with this guide. Use care when handling the ribbon cable to avoid damage to internal components.
Tools
Show more…
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement, Back Cover: step 1, image 1 of 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 2, image 1 of 2 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 3, image 1 of 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement, Pen Charging Port: step 4, image 1 of 1
    • Remove the pen from its slot on the side of the laptop before removing the pen charging port.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 5, image 1 of 2 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 5, image 2 of 2
    Tool used on this step:
    $3.99
    • Lift the tab with a spudger to expose the ribbon cable.
    • Do not use the metal spudger unless if it's for serious prying power. The metal spudger may damage or puncture the internal components in your device, so please use a plastic opening tool or nylon spudger instead.
    • Carefully pull out the ribbon cable using Pro/ESD/angled tweezers.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 6, image 1 of 2 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 6, image 2 of 2
    • Disconnect the red and black charger wire from the port on the circuit board.
    • Remove two 4 mm screws using the Phillips #0 screwdriver.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 7, image 1 of 1
    • Remove the circuit board by hand.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 8, image 1 of 2 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: step 8, image 2 of 2
    • Remove a single 6 mm screw from the charging port using the Phillips #0 screwdriver.
    • Remove the black charging port using your fingers.
Katrina Lee
162 Reputation
1 Guide authored
Cal Poly, Team S22-G3, Regan Winter 2020 Member of Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 23
All Time: 2,403
