Lenovo ThinkPad X1 Yoga Cooling Fan Replacement
  1. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement, Back Cover: step 1, image 1 of 3 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement, Back Cover: step 1, image 2 of 3 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement, Back Cover: step 1, image 3 of 3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement, Cooling Fan: step 2, image 1 of 1
    • Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
  3. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: step 3, image 1 of 3 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: step 3, image 2 of 3 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: step 3, image 3 of 3
    • Gently peel back the black plastic covering around the fan.
    • You may hear or feel the adhesive pulling away here.
    • Using an iFixit opening tool, flip up the small black cover of the fan plug.
  4. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: step 4, image 1 of 2 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, pull the plastic strip out.
  5. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: step 5, image 1 of 2 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: step 5, image 2 of 2
    • Remove the fan from the computer.
2 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 123
All Time: 6,275
