Lenovo ThinkPad X1 Yoga Motherboard Replacement
  1. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Back Cover: step 1, image 1 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Back Cover: step 1, image 2 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Back Cover: step 1, image 3 of 3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Speakers: step 2, image 1 of 1
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 4, image 1 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 4, image 2 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 4, image 3 of 3
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Battery: step 5, image 1 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Battery: step 5, image 2 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Battery: step 5, image 3 of 3
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 6, image 1 of 1
    • Lift and remove the battery away from the computer.
  7. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Cooling Fan: step 7, image 1 of 1
    • Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
  8. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 8, image 1 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 8, image 2 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 8, image 3 of 3
    • Gently peel back the black plastic covering around the fan.
    • You may hear or feel the adhesive pulling away here.
    • Using an iFixit opening tool, flip up the small black cover of the fan plug.
  9. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 9, image 1 of 2 Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 9, image 2 of 2
    Buy
    • Using tweezers, pull the plastic strip out.
  10. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 10, image 1 of 2 Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 10, image 2 of 2
    • Remove the fan from the computer.
  11. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Wireless chip: step 11, image 1 of 1
    • Gently peel back the black plastic covering.
    • Remove the single Phillips #1 screw securing the wireless chip in place.
  12. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 12, image 1 of 2 Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 12, image 2 of 2
    • Use an iFixit opening tool to gently pop the gold caps off their connections.
    • Move these wires out of the way.
  13. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 13, image 1 of 1
    • Slide the chip out.
  14. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Hard Drive: step 14, image 1 of 2 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Hard Drive: step 14, image 2 of 2
    • Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
  15. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 15, image 1 of 1
    • Unplug the hard drive from the computer by pulling away from the computer.
  16. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Motherboard: step 16, image 1 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Motherboard: step 16, image 2 of 3 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Motherboard: step 16, image 3 of 3
    • Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
    • Gently pull the cables out of the slots.
  17. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 17, image 1 of 2 Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 17, image 2 of 2
    • Using the Phillips #1 screwdriver, remove sixteen 4.5mm screws.
  18. Lenovo ThinkPad X1 Yoga Motherboard Replacement: step 18, image 1 of 1
    • Lift and remove the motherboard away from the computer.
0 Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 100
All Time: 4,415
