Lenovo ThinkPad X100e RAM Replacement
  1. Lenovo ThinkPad X100e RAM Replacement, RAM: step 1, image 1 of 1
    • Power off the device completely.
    • Use the Phillips #0 screwdriver to remove the seven screws that are holding the bottom cover in place.
    • Remove the back cover from the frame.
  2. Lenovo ThinkPad X100e RAM Replacement: step 2, image 1 of 1
    • The RAM will be located at the bottom right corner of the laptop.
  3. Lenovo ThinkPad X100e RAM Replacement: step 3, image 1 of 2 Lenovo ThinkPad X100e RAM Replacement: step 3, image 2 of 2
    • Pull the two mounting clips on either side of the RAM stick away from the RAM stick.
    • The RAM should lift up 30 degrees. Slide it out gently as to not damage the pins.
Replace the RAM by sliding the new stick back into the empty slot until it clicks into place.
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 33
All Time: 1,128
