Lenovo ThinkPad X100e Thermal Paste Replacement
  1. Lenovo ThinkPad X100e Thermal Paste Replacement, Opening the laptop (1).: step 1, image 1 of 2 Lenovo ThinkPad X100e Thermal Paste Replacement, Opening the laptop (1).: step 1, image 2 of 2
    • Unscrew the 7 screws holding the back panel in place.
    • Remove the battery by sliding the notches and pulling the battery outwards.
    • Remove the screws that are marked to release the keyboard.
  2. Lenovo ThinkPad X100e Thermal Paste Replacement, Opening the laptop (2).: step 2, image 1 of 3 Lenovo ThinkPad X100e Thermal Paste Replacement, Opening the laptop (2).: step 2, image 2 of 3 Lenovo ThinkPad X100e Thermal Paste Replacement, Opening the laptop (2).: step 2, image 3 of 3
    • Carefully lift up the keyboard and unplug it and the touchpad.
    • Remove the 2 screws that hold the panel in place.
  3. Lenovo ThinkPad X100e Thermal Paste Replacement, Opening the laptop (3).: step 3, image 1 of 2 Lenovo ThinkPad X100e Thermal Paste Replacement, Opening the laptop (3).: step 3, image 2 of 2
    • Use a prying tool to carefully release all the clips holding the panel in place and remove it.
  4. Lenovo ThinkPad X100e Thermal Paste Replacement, Removing the motherboard.: step 4, image 1 of 3 Lenovo ThinkPad X100e Thermal Paste Replacement, Removing the motherboard.: step 4, image 2 of 3 Lenovo ThinkPad X100e Thermal Paste Replacement, Removing the motherboard.: step 4, image 3 of 3
    • Unplug the cables and remove all the screws that hold the motherboard to the panel.
    • Carefully remove the motherboard and flip it around to reveal the heatsink and fan assembly.
    • Unscrew it from the motherboard and disconnect the fan cable.
  5. Lenovo ThinkPad X100e Thermal Paste Replacement, Applying new thermal paste, cleaning and optional upgrades.: step 5, image 1 of 3 Lenovo ThinkPad X100e Thermal Paste Replacement, Applying new thermal paste, cleaning and optional upgrades.: step 5, image 2 of 3 Lenovo ThinkPad X100e Thermal Paste Replacement, Applying new thermal paste, cleaning and optional upgrades.: step 5, image 3 of 3
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink. It is good to replace the thermal pad as well, but not mandatory if it is still good.
    • You can also open the fan itself and clean it further if necessary.
    • Once you have opened the laptop, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
Simeon Brankov
6,448 Reputation
51 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 14
All Time: 310
