Lenovo ThinkPad X140e Back Panel Replacement
  1. Lenovo ThinkPad X140e Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Flip the laptop upside down so that the battery is facing away from you.
    • Battery removal is not necessary to complete this guide.
  2. Lenovo ThinkPad X140e Back Panel Replacement: step 2, image 1 of 2 Lenovo ThinkPad X140e Back Panel Replacement: step 2, image 2 of 2
    • Locate the three 3 mm Phillips #0 screws on the back panel.
    • Remove each screw using a small Phillips #0 screwdriver.
  3. Lenovo ThinkPad X140e Back Panel Replacement: step 3, image 1 of 1
    • Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
Kenneth nguyen
214 Reputation
1 Guide authored
Cal Poly, Team 20-5, Livingston Fall 2016 Member of Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 486
