Lenovo ThinkPad X140e Battery Replacement
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: step 2, image 1 of 1
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: step 3, image 1 of 2 Lenovo ThinkPad X140e Battery Replacement: step 3, image 2 of 2
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
Dylan Halland
318 Reputation
2 Guides authored
Cal Poly, Team 20-5, Livingston Fall 2016 Member of Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Members
5 Guides authored
One Comment
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 992
