Lenovo ThinkPad X280 Fingerprint Scanner Replacement
  1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Back Panel: step 1, image 1 of 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: step 2, image 1 of 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: step 3, image 1 of 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: step 3, image 2 of 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: step 4, image 1 of 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: step 4, image 2 of 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: step 4, image 3 of 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: step 5, image 1 of 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: step 5, image 2 of 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: step 5, image 3 of 3
    • Using a Phillips #1 screwdriver, remove one 5 mm screw from the fingerprint sensor.
    • Remove the metal plate covering the sensor.
  6. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: step 6, image 1 of 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: step 6, image 2 of 2
    • Using the black spudger tool, flip up the small hinged locking flap connected to the motherboard.
    • Gently pull the cable out of the connection site.
  7. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: step 7, image 1 of 1
    • Remove fingerprint scanner and metal covering from device.
2 other people completed this guide.
Jordan Wooten
621 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,716
