Lenovo ThinkPad X280 Speaker Replacement
  1. Lenovo ThinkPad X280 Speaker Replacement, Back Panel: step 1, image 1 of 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Speaker Replacement: step 2, image 1 of 2 Lenovo ThinkPad X280 Speaker Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Speaker Replacement: step 3, image 1 of 2 Lenovo ThinkPad X280 Speaker Replacement: step 3, image 2 of 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Speaker Replacement, Battery: step 4, image 1 of 3 Lenovo ThinkPad X280 Speaker Replacement, Battery: step 4, image 2 of 3 Lenovo ThinkPad X280 Speaker Replacement, Battery: step 4, image 3 of 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Speaker Replacement, Speakers: step 5, image 1 of 3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: step 5, image 2 of 3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: step 5, image 3 of 3
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each speaker.
    • Once done, the speakers should still be attached with a red wire connecting to each other.
  6. Lenovo ThinkPad X280 Speaker Replacement: step 6, image 1 of 2 Lenovo ThinkPad X280 Speaker Replacement: step 6, image 2 of 2
    • Using the black spudger, push the white plastic connector out of the the tan plug.
  7. Lenovo ThinkPad X280 Speaker Replacement: step 7, image 1 of 1
    • Remove speakers and wiring from device.
Jordan Wooten
609 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 53
All Time: 1,467
