Lenovo ThinkPad X390 Motherboard Replacement
  1. Lenovo ThinkPad X390 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Power down and unplug the laptop before proceeding.
    • Use a Phillips #0 screwdriver to remove the five screws on the base cover.
  2. Lenovo ThinkPad X390 Motherboard Replacement: step 2, image 1 of 1
    • Insert a plastic opening tool between the base cover and the chassis.
    • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
    • Lift the base cover up and off.
  3. Lenovo ThinkPad X390 Motherboard Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
  4. Lenovo ThinkPad X390 Motherboard Replacement: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
  5. Lenovo ThinkPad X390 Motherboard Replacement: step 5, image 1 of 1
    • Lift the battery up and out of its housing.
  6. Lenovo ThinkPad X390 Motherboard Replacement: step 6, image 1 of 2 Lenovo ThinkPad X390 Motherboard Replacement: step 6, image 2 of 2
    • Remove the four 5.2 mm screws from the fan using the Phillips #0 screwdriver.
    • Use tweezers to carefully unplug the fan ribbon cable.
  7. Lenovo ThinkPad X390 Motherboard Replacement: step 7, image 1 of 1
    • Remove the eleven 5.2 mm screws from the motherboard using a Phillips #0 screwdriver.
  8. Lenovo ThinkPad X390 Motherboard Replacement: step 8, image 1 of 1
    • Use tweezers to carefully unplug the four motherboard ribbon cables.
  9. Lenovo ThinkPad X390 Motherboard Replacement: step 9, image 1 of 1
    • Use tweezers to carefully unplug the black and red harness cables.
  10. Lenovo ThinkPad X390 Motherboard Replacement: step 10, image 1 of 1
    • Carefully lift the motherboard up and out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 41
All Time: 2,318
