Lenovo ThinkPad X390 Yoga Motherboard Replacement
  1. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Back Case: step 1, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 2, image 1 of 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 3, image 1 of 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Battery: step 4, image 1 of 1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 5, image 1 of 1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 6, image 1 of 1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Fan: step 7, image 1 of 1
    • Disconnect the fan connector from the moetherboard with a spudger or opening tool.
  8. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 8, image 1 of 1
    • Loosen the seven screws surrounding the fan and heatsink using the Phillips #1 screwdriver.
  9. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 9, image 1 of 1
    • Carefully remove the fan from the laptop by lifting it up and off the frame.
  10. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • Disconnect the motherboard connectors with a spudger or opening tool.
  11. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 11, image 1 of 1
    • Use the Phillips #1 screwdriver to remove nine 5 mm screws around the motherboard.
  12. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 12, image 1 of 1
    • Loosen the sixty-eight 2 mm screws using the Phillips #1 screwdriver.
  13. Lenovo ThinkPad X390 Yoga Motherboard Replacement: step 13, image 1 of 1
    • Carefully remove the motherboard from the laptop by lifting it up and off the frame.
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 44
All Time: 587
