Lenovo ThinkPad X390 Yoga SSD Replacement
  1. Lenovo ThinkPad X390 Yoga SSD Replacement, Back Case: step 1, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga SSD Replacement: step 2, image 1 of 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga SSD Replacement: step 3, image 1 of 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga SSD Replacement, SSD: step 4, image 1 of 1
    • Use the Phillips #1 screwdriver to remove the 4 mm screw holding the SSD in place .
  5. Lenovo ThinkPad X390 Yoga SSD Replacement: step 5, image 1 of 1
    • Pull the SSD out from the connection to remove it.
Scott Merchant
90 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 79
All Time: 1,520
