Lenovo ThinkPad X61 Battery Replacement
  1. Lenovo ThinkPad X61 Battery Replacement, Battery: step 1, image 1 of 1
    • The first step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • You should then find the battery lock release located in the top left corner, as indicated in the image.
  2. Lenovo ThinkPad X61 Battery Replacement: step 2, image 1 of 1
    • The next step is to simply move the switch from the locked position to the unlocked position.
  3. Lenovo ThinkPad X61 Battery Replacement: step 3, image 1 of 1
    • Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Simply move the switch over from the locked position to the unlocked position and pull the battery from its holder. You can now insert the new battery.
2 other people completed this guide.
Ryan McCarthy
772 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 1,181
