Lenovo ThinkPad Yoga 14 20FY Fan Replacement
  1. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Back Cover: step 1, image 1 of 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Back Cover: step 1, image 2 of 2
    • Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
    • The screws do not come all the way out. Do not force them out.
  2. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: step 2, image 1 of 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: step 2, image 2 of 2
    • After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
  3. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Fan: step 3, image 1 of 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement, Fan: step 3, image 2 of 2
    • Remove all 7 screws.
    • One of the screws is behind a black piece of the plastic.
  4. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: step 4, image 1 of 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: step 4, image 2 of 2
    • Use the flat end of the spudger to push the connector out of its socket .
    • Do not use the wire to pull the connector out!
  5. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: step 5, image 1 of 2 Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: step 5, image 2 of 2
    • There is a wire looped around the fan. Use the spudger to pull the wires out of the loop.
  6. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: step 6, image 1 of 1
    • Gently peel back a piece of tape in the bottom left corner of the fan.
  7. Lenovo ThinkPad Yoga 14 20FY  Fan  Replacement: step 7, image 1 of 1
    • Gently lift out the fan.
jose aguirre
264 Reputation
2 Guides authored
Cal Poly, Team S14-G2, Banghart Spring 2017 Member of Cal Poly, Team S14-G2, Banghart Spring 2017
CPSU-BANGHART-S17S14G2
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,456
