Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement
  1. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Back Cover: step 1, image 1 of 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 2, image 1 of 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 3, image 1 of 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 3, image 2 of 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 4, image 1 of 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 4, image 2 of 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Heat Sink: step 5, image 1 of 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Heat Sink: step 5, image 2 of 2
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  6. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 6, image 1 of 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 6, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
    • The screws will not separate from the mounting when loose.
  7. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: step 7, image 1 of 1
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
3 other people completed this guide.
Daniel Fernandez
963 Reputation
5 Guides authored
USF Tampa, Team S2-G3, Eyestone Spring 2018 Member of USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 Members
5 Guides authored
One Comment
Good guide, thank you. Clear and concise with very easy to follow pictures and instruction. As usual, iFixit to the rescue :-)
Mark Taylor (wodin69) - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 1,243
