Lenovo ThinkPad Yoga 260 Trackpad Replacement
  1. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Back Cover: step 1, image 1 of 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 2, image 1 of 2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 3, image 1 of 2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 3, image 2 of 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 4, image 1 of 2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 4, image 2 of 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: step 5, image 1 of 3 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: step 5, image 2 of 3 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: step 5, image 3 of 3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 6, image 1 of 3 Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 6, image 2 of 3 Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 6, image 3 of 3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: step 7, image 1 of 3 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: step 7, image 2 of 3 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: step 7, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the four 1.3mm Philips #1 fasteners from the back of the trackpad and set them aside.
  8. Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 8, image 1 of 2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 8, image 2 of 2
    • Using your index finger and thumb gently pull the blue tab located at the top of the trackpad back from the assembly.
  9. Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 9, image 1 of 3 Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 9, image 2 of 3 Lenovo ThinkPad Yoga 260 Trackpad Replacement: step 9, image 3 of 3
    • Flip the device right side up.
    • Open the computer.
    • Gently lift the trackpad out of the computer assembly.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,330
