Lenovo ThinkPad Yoga 370 Screen Replacement
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: step 1, image 1 of 1
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: step 2, image 1 of 2 Lenovo ThinkPad Yoga 370 Screen Replacement: step 2, image 2 of 2
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: step 4, image 1 of 1
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: step 5, image 1 of 3 Lenovo ThinkPad Yoga 370 Screen Replacement: step 5, image 2 of 3 Lenovo ThinkPad Yoga 370 Screen Replacement: step 5, image 3 of 3
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
One Comment
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - Reply
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 66
All Time: 2,343
