Lenovo ThinkPad Yoga Fan Replacement
  1. Lenovo ThinkPad Yoga Fan Replacement, Battery: step 1, image 1 of 3 Lenovo ThinkPad Yoga Fan Replacement, Battery: step 1, image 2 of 3 Lenovo ThinkPad Yoga Fan Replacement, Battery: step 1, image 3 of 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Fan Replacement: step 2, image 1 of 3 Lenovo ThinkPad Yoga Fan Replacement: step 2, image 2 of 3 Lenovo ThinkPad Yoga Fan Replacement: step 2, image 3 of 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Fan Replacement, Speakers: step 3, image 1 of 3 Lenovo ThinkPad Yoga Fan Replacement, Speakers: step 3, image 2 of 3 Lenovo ThinkPad Yoga Fan Replacement, Speakers: step 3, image 3 of 3
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Fan Replacement, Fan: step 4, image 1 of 3 Lenovo ThinkPad Yoga Fan Replacement, Fan: step 4, image 2 of 3 Lenovo ThinkPad Yoga Fan Replacement, Fan: step 4, image 3 of 3
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
Craig
217 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 32
All Time: 490
