Lenovo ThinkPad Yoga RAM Replacement
  1. Lenovo ThinkPad Yoga RAM Replacement, Battery: step 1, image 1 of 3 Lenovo ThinkPad Yoga RAM Replacement, Battery: step 1, image 2 of 3 Lenovo ThinkPad Yoga RAM Replacement, Battery: step 1, image 3 of 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad Yoga RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad Yoga RAM Replacement: step 2, image 3 of 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga RAM Replacement, RAM: step 3, image 1 of 3 Lenovo ThinkPad Yoga RAM Replacement, RAM: step 3, image 2 of 3 Lenovo ThinkPad Yoga RAM Replacement, RAM: step 3, image 3 of 3
    • Remove nine screws from the motherboard with a Phillips #1 screwdriver.
    • Remove all ribbon cables attached to the motherboard.
    • Lift the motherboard out of the device.
  4. Lenovo ThinkPad Yoga RAM Replacement: step 4, image 1 of 3 Lenovo ThinkPad Yoga RAM Replacement: step 4, image 2 of 3 Lenovo ThinkPad Yoga RAM Replacement: step 4, image 3 of 3
    • Desolder the RAM to replace it.
    • You may also opt to replace the entire motherboard if soldering is not an option.
Michael Nessralla
171 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 64
All Time: 1,513
