Lenovo Thinkpad E540 Display Screen Replacement
  1. Lenovo Thinkpad E540 Display Screen Replacement, Battery: step 1, image 1 of 2 Lenovo Thinkpad E540 Display Screen Replacement, Battery: step 1, image 2 of 2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Display Screen Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. Lenovo Thinkpad E540 Display Screen Replacement, Display Screen: step 3, image 1 of 1
    • Remove the two stickers at the bottom corners for the screen to reveal the screws.
    • Remove the two 1mm Phillips #00 screws from underneath the stickers.
  4. Lenovo Thinkpad E540 Display Screen Replacement: step 4, image 1 of 1
    • Slide your finger underneath the plastic and pry gently to release the clips around the display bezel.
  5. Lenovo Thinkpad E540 Display Screen Replacement: step 5, image 1 of 1
    • Remove the six 1.3mm Phillips #00 screws from around the display.
  6. Lenovo Thinkpad E540 Display Screen Replacement: step 6, image 1 of 1
    • Remove the plastic covering and six 1.3mm Phillips #00 screws from both sides of the display.
  7. Lenovo Thinkpad E540 Display Screen Replacement: step 7, image 1 of 3 Lenovo Thinkpad E540 Display Screen Replacement: step 7, image 2 of 3 Lenovo Thinkpad E540 Display Screen Replacement: step 7, image 3 of 3
    • Remove the orange tape covering the display connector.
    • Disconnect the display's ribbon cable by lifting up the latch and flipping it over 180 degrees.
Timothy Sumner
1,046 Reputation
8 Guides authored
USF Tampa, Team S2-G5, Nance Spring 2018 Member of USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 4,822
