Lenovo Thinkpad Edge E545 Hard Drive Replacement
  1. Lenovo Thinkpad Edge E545 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • First, flip the laptop over as shown in the photo.
    • Make sure device is fully powered down before removing battery.
  2. Lenovo Thinkpad Edge E545 Hard Drive Replacement: step 2, image 1 of 1
    • Below the battery are two small tabs. These function as a lock for the battery.
    • Push the tabs towards each other to release the battery.
  3. Lenovo Thinkpad Edge E545 Hard Drive Replacement: step 3, image 1 of 1
    • Remove the battery from the device.
  4. Lenovo Thinkpad Edge E545 Hard Drive Replacement, Back Panel: step 4, image 1 of 1
    • Using a Phillips screwdriver, remove the four screws around the edges of the rectangular panel.
    • It is recommend that you fully remove the screws and place them in a secure location.
    • Make sure to use the appropriate sized screwdriver. The wrong size can cause damage to the screws or screwdriver.
  5. Lenovo Thinkpad Edge E545 Hard Drive Replacement: step 5, image 1 of 2 Lenovo Thinkpad Edge E545 Hard Drive Replacement: step 5, image 2 of 2
    • Once all the screws are removed, gently slide the metal scalp around the edge of the panel to pry it open.
    • Slowly lift the left edge side of the panel with your fingers. Once the left side is up, continue lifting the right edge of the panel.
  6. Lenovo Thinkpad Edge E545 Hard Drive Replacement: step 6, image 1 of 1
    • Remove the back panel.
    • The back of the laptop will be exposed once the panel is removed.
    • Many of these small components are easily damaged--do not touch anything unless instructed to.
  7. Lenovo Thinkpad Edge E545 Hard Drive Replacement, Hard Drive: step 7, image 1 of 2 Lenovo Thinkpad Edge E545 Hard Drive Replacement, Hard Drive: step 7, image 2 of 2
    • After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver.
  8. Lenovo Thinkpad Edge E545 Hard Drive Replacement: step 8, image 1 of 1
    • After screws are removed, slide the hard drive down to disconnect from motherboard and remove it.
  9. Lenovo Thinkpad Edge E545 Hard Drive Replacement: step 9, image 1 of 1
    • Now you have successfully removed the Hard drive.
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,032
