Lenovo Thinkpad Screen Replacement
  1. Lenovo Thinkpad Screen Replacement, Remove screen cover: step 1, image 1 of 2 Lenovo Thinkpad Screen Replacement, Remove screen cover: step 1, image 2 of 2
    • This cover is glued to the laptop. Please use caution as you use a spudger to disconnect the glue from the edge of the computer screen. Make sure the glue stays in tact on the cover.
    • Use the spudger all the way around to pry the cover loose.
  2. Lenovo Thinkpad Screen Replacement, Remove the screws: step 2, image 1 of 3 Lenovo Thinkpad Screen Replacement, Remove the screws: step 2, image 2 of 3 Lenovo Thinkpad Screen Replacement, Remove the screws: step 2, image 3 of 3
    • Once the cover is off, you will see the screen is held in with 4 Phillips head screws.
    • Remove all 4 screws as shown.
  3. Lenovo Thinkpad Screen Replacement, Removing the screen: step 3, image 1 of 2 Lenovo Thinkpad Screen Replacement, Removing the screen: step 3, image 2 of 2
    • Once you have removed the screws, the monitor will be free.
    • The best way to take the monitor out is to gently pull the top of it away from the case. As you can see it is connected at the bottom by the video connection.
    • To remove the screen completely you must disconnect this video connection. There is a very thin metal tab (see picture) that will pry up and allow the connection to disconnect.
  4. Lenovo Thinkpad Screen Replacement, New screen: step 4, image 1 of 1
    • The screen is now disconnected.
    • Once you have a replacement screen you can connect it in reverse order.
4 other people completed this guide.
Bill
884 Reputation
5 Guides authored
8 Guide Comments
Thanks for posting - this is much easier than I expected and your posting made it truly a simple task!!
Rob Campbell - Reply
Will a screen of a T460s or aT470s fit a T480s ?
c.evagelidakis - Reply
I haven’t had a chance to check the T480 screen to see if it is the same connection.
Bill -
Do you need to apply some type of adhesive to put the front panel back on after replacing the screen?
Matt - Reply
No, you just need to put the screws back
ROHIT BHUSAM -
Past 24 Hours: 23
Past 7 Days: 92
Past 30 Days: 427
All Time: 22,532
