Lenovo Thinkpad T440s Thermal Paste Replacement
  1. Lenovo Thinkpad T440s Thermal Paste Replacement, Back Panel: step 1, image 1 of 2 Lenovo Thinkpad T440s Thermal Paste Replacement, Back Panel: step 1, image 2 of 2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Thermal Paste Replacement: step 2, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Thermal Paste Replacement: step 3, image 1 of 2 Lenovo Thinkpad T440s Thermal Paste Replacement: step 3, image 2 of 2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Thermal Paste Replacement: step 4, image 1 of 1
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Thermal Paste Replacement, Thermal Paste: step 5, image 1 of 2 Lenovo Thinkpad T440s Thermal Paste Replacement, Thermal Paste: step 5, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the four screws securing the fan to gain access to the processor.
  6. Lenovo Thinkpad T440s Thermal Paste Replacement: step 6, image 1 of 2 Lenovo Thinkpad T440s Thermal Paste Replacement: step 6, image 2 of 2
    • Lift the fan assembly to gain access to the thermal paste. From here, the thermal paste can be wiped away and replaced. Make sure to only apply new thermal paste to the larger die; don't apply any to the smaller one.
6 other people completed this guide.
Terelle Montalvo
1,477 Reputation
8 Guides authored
One Comment
I replaced the SSD and decided to replace the heat conductive paste too. It was a good move as the paste had completely dried out. The replacement was effortless and the provided instructions were spot on, confirming my assumptions. Lenovo devices are excellent for self-repair.
Dominik Widmann - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 26
All Time: 2,661
