Lenovo Thinkpad T450 CMOS Battery Replacement
  1. Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: step 1, image 1 of 3 Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: step 1, image 2 of 3 Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: step 1, image 3 of 3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 CMOS Battery Replacement, Back Cover: step 2, image 1 of 1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 CMOS Battery Replacement: step 3, image 1 of 3 Lenovo Thinkpad T450 CMOS Battery Replacement: step 3, image 2 of 3 Lenovo Thinkpad T450 CMOS Battery Replacement: step 3, image 3 of 3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: step 4, image 1 of 3 Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: step 4, image 2 of 3 Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: step 4, image 3 of 3
    • Using the plastic opening tool, disconnect the CMOS battery from the motherboard.
  5. Lenovo Thinkpad T450 CMOS Battery Replacement: step 5, image 1 of 2 Lenovo Thinkpad T450 CMOS Battery Replacement: step 5, image 2 of 2
    • Insert the plastic opening tool underneath the CMOS battery and pry it up and away from the motherboard.
    • When you reassemble your device, you may need to reapply adhesive to the back of the CMOS battery.
2 other people completed this guide.
Justin Ogihara
27,788 Reputation
52 Guides authored
EDU Team Member of EDU Team
Staff
7 Members
677 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 62
Past 30 Days: 294
All Time: 10,071
