Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement
  1. Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement, External Battery: step 1, image 1 of 3 Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement, External Battery: step 1, image 2 of 3 Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement, External Battery: step 1, image 3 of 3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement, Back Cover: step 2, image 1 of 1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement: step 3, image 1 of 3 Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement: step 3, image 2 of 3 Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement: step 3, image 3 of 3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement, RAM: step 4, image 1 of 2 Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement, RAM: step 4, image 2 of 2
    • Lift up the black piece of tape and remove it to uncover the RAM sticks underneath.
  5. Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement: step 5, image 1 of 2 Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement: step 5, image 2 of 2
    • Using your fingers, push the two clips securing the RAM away from each other to release the RAM.
    • The RAM stick should pop up at a 30 degree angle.
    • Remove the RAM stick from the device.
    • Repeat this step for any additional RAM sticks.
  6. Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: step 6, image 1 of 1
    • Using the JIS #00 screwdriver, unscrew the four screws securing the fan and heatsink assembly to the motherboard.
    • These screws are not removable and will stay on the fan and heatsink assembly.
  7. Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement: step 7, image 1 of 1
    • Disconnect the fan and heatsink assembly from the motherboard using the plastic opening tool.
  8. Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement: step 8, image 1 of 2 Lenovo Thinkpad T450 Fan and Heatsink Assembly Replacement: step 8, image 2 of 2
    • Lift up the fan and heatsink assembly and remove it from the device.
    • When you reassemble your device, don't forget to reapply thermal paste to the back of the heatsink and fan assembly. For proper technique and thermal paste application, please visit the How to Apply Thermal Paste guide.
Don’t forget to reapply thermal paste to the fan and heatsink assembly when you reassemble your device.
Justin Ogihara
27,788 Reputation
52 Guides authored
EDU Team Member of EDU Team
Staff
7 Members
677 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 50
All Time: 2,450
