Lenovo Thinkpad T450s Motherboard Replacement
  1. Lenovo Thinkpad T450s Motherboard Replacement, Fan: step 1, image 1 of 1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Motherboard Replacement: step 2, image 1 of 1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Motherboard Replacement: step 3, image 1 of 1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Motherboard Replacement: step 4, image 1 of 1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
  5. Lenovo Thinkpad T450s Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Remove all twelve 3.6 mm Phillips #00 screws.
  6. Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: step 6, image 1 of 2 Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: step 6, image 2 of 2
    • Remove the hard drive from the motherboard's by gently pulling it out and up at the same time.
  7. Lenovo Thinkpad T450s Motherboard Replacement: step 7, image 1 of 1
    • Pull out the socket that is attached to the left side of the battery case.
  8. Lenovo Thinkpad T450s Motherboard Replacement: step 8, image 1 of 1
    • Unplug the cable that attaches the polymer battery to the motherboard by pulling it out carefully.
  9. Lenovo Thinkpad T450s Motherboard Replacement: step 9, image 1 of 1
    • Remove the ribbon cable attached to the the battery case carefully by pulling the cable up and out.
  10. Lenovo Thinkpad T450s Motherboard Replacement: step 10, image 1 of 1
    • Remove the motherboard from the case. If the motherboard does not come off the case or feels stuck, make sure that you have removed all the cables prior
2 other people completed this guide.
Sara Karimi Razakani
178 Reputation
1 Guide authored
IUPUI, Team 2-3, Harley Spring 2022 Member of IUPUI, Team 2-3, Harley Spring 2022
IUPUI-HARLEY-S22S2G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 41
All Time: 1,305
