Lenovo Thinkpad T450s RAM Replacement
  1. Lenovo Thinkpad T450s RAM Replacement, Battery: step 1, image 1 of 2 Lenovo Thinkpad T450s RAM Replacement, Battery: step 1, image 2 of 2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s RAM Replacement: step 2, image 1 of 1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s RAM Replacement: step 3, image 1 of 2 Lenovo Thinkpad T450s RAM Replacement: step 3, image 2 of 2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: step 4, image 1 of 3 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: step 4, image 2 of 3 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: step 4, image 3 of 3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s RAM Replacement: step 5, image 1 of 2 Lenovo Thinkpad T450s RAM Replacement: step 5, image 2 of 2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
  6. Lenovo Thinkpad T450s RAM Replacement, RAM: step 6, image 1 of 3 Lenovo Thinkpad T450s RAM Replacement, RAM: step 6, image 2 of 3 Lenovo Thinkpad T450s RAM Replacement, RAM: step 6, image 3 of 3
    • Pull one side of the prong that is holding the RAM in place
  7. Lenovo Thinkpad T450s RAM Replacement: step 7, image 1 of 1
    • Pull the other side prong until the RAM pops up.
  8. Lenovo Thinkpad T450s RAM Replacement: step 8, image 1 of 2 Lenovo Thinkpad T450s RAM Replacement: step 8, image 2 of 2
    • Pull the RAM out of the device
One Comment
My t450s comes with an internal battery. The comment on this guide records the process for disabling the internal battery temporarily.
I also used this guide from Lenovo as I found removing the back plate rather difficult.
ray beats - Reply
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 49
All Time: 5,048
