Lenovo Thinkpad X220 HDD Replacement
  1. Lenovo Thinkpad X220 HDD Replacement, HDD: step 1, image 1 of 1
    • Put the laptop upside down.
  2. Lenovo Thinkpad X220 HDD Replacement: step 2, image 1 of 2 Lenovo Thinkpad X220 HDD Replacement: step 2, image 2 of 2
    • Unscrew the HDD slot cover.
  3. Lenovo Thinkpad X220 HDD Replacement: step 3, image 1 of 2 Lenovo Thinkpad X220 HDD Replacement: step 3, image 2 of 2
    • You will arrive to something like this.
    • Pull the black tab popping out to remove the HDD from its tray.
    • The little black tab can be fragile. I recommend you to put tape on it when you have removed the HDD from the bracket to make it tougher.
  4. Lenovo Thinkpad X220 HDD Replacement: step 4, image 1 of 2 Lenovo Thinkpad X220 HDD Replacement: step 4, image 2 of 2
    • Congratulations! You got the HDD out of the laptop. We can now put the laptop somewhere else and focus on the HDD.
    • On each long side of the HDD, two rubber bands are located. Pull them to remove them and access to the screws.
  5. Lenovo Thinkpad X220 HDD Replacement: step 5, image 1 of 1
    • Unscrew the 4 screws located on the two long sides of the drives...
    • ...and push the HDD outside from its retention bracket.
  6. Lenovo Thinkpad X220 HDD Replacement: step 6, image 1 of 1
    • You're done! To reassemble, place a new drive in the bracket and follow the steps in the reverse order.
13 other people completed this guide.
alphaLONE
927 Reputation
3 Guides authored
5 Comments
I just hope that a 64 year old crazy cat lady can do this without blowing up the galaxy
Bobbi Johnson - Reply
Thanks dude.
Asrul LLC - Reply
What size drives will fit?
Dan - Reply
7mm thick, no more. (I tried with a thicker HyperX 240gb drive but it was too big, wouldn’t fit)
alphaLONE -
eine feine Anleitung. Bravo!
Leitner Josef - Reply
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 47
All Time: 16,176
