Lenovo Thinkpad x230 Motherboard Replacement
  1. Lenovo Thinkpad x230 Motherboard Replacement, Preparations: step 1, image 1 of 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 Motherboard Replacement, Locate the battery: step 2, image 1 of 1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Motherboard Replacement, Unlock the left switch: step 3, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Unlock the left switch: step 3, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Unlock the left switch: step 3, image 3 of 3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Motherboard Replacement, Remove the battery: step 4, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Remove the battery: step 4, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Remove the battery: step 4, image 3 of 3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
  5. Lenovo Thinkpad x230 Motherboard Replacement, Locate the hard drive enclosure: step 5, image 1 of 1
    • Locate the hard drive enclosure (marked by the red rectangle).
  6. Lenovo Thinkpad x230 Motherboard Replacement, Remove enclosure: step 6, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement, Remove enclosure: step 6, image 2 of 2
    • Use a small Phillips screwdriver to unscrew the single screw that holds down the hard drive enclosure cover.
    • The screw is designed to remain within the plastic cover. Don't worry about extracting it completely.
    • Carefully remove the hard drive enclosure cover.
  7. Lenovo Thinkpad x230 Motherboard Replacement, Remove SSD/hard drive: step 7, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Remove SSD/hard drive: step 7, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Remove SSD/hard drive: step 7, image 3 of 3
    • Gently pull the black pull tab out from above the hard drive. Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
    • Pull on the tab firmly but slowly. The hard drive should come out of the enclosure effortlessly.
  8. Lenovo Thinkpad x230 Motherboard Replacement, Remove plastic rails: step 8, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Remove plastic rails: step 8, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Remove plastic rails: step 8, image 3 of 3
    • Remove the plastic rails from the old SSD/hard drive and place them on the new SSD/hard drive.
  9. Lenovo Thinkpad x230 Motherboard Replacement, remove screws: step 9, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement, remove screws: step 9, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement, remove screws: step 9, image 3 of 3
    • There are 2 screws securing the keyboard. You can identify them by a small keyboard symbol (marked by an orange rectangle in the second picture).
    • Once you have located the two screws, remove them with a small Phillips screwdriver.
  10. Lenovo Thinkpad x230 Motherboard Replacement, remove strip above keyboard: step 10, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement, remove strip above keyboard: step 10, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement, remove strip above keyboard: step 10, image 3 of 3
    • This step is not required.
    • Gently pull the strip out from the case.
  11. Lenovo Thinkpad x230 Motherboard Replacement, pop keyboard out of the casing: step 11, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement, pop keyboard out of the casing: step 11, image 2 of 2
    • Use a a plastic spudger (or a flat screwdriver) to push the keyboard towards the screen. This will pop the bottom of the keyboard out of the casing.
  12. Lenovo Thinkpad x230 Motherboard Replacement, lift keyboard: step 12, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement, lift keyboard: step 12, image 2 of 2
    • Carefully lift the keyboard so that you can access its connector.
  13. Lenovo Thinkpad x230 Motherboard Replacement, Unplug keyboard: step 13, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement, Unplug keyboard: step 13, image 2 of 2
    • Carefully unplug the connector by pulling.
  14. Lenovo Thinkpad x230 Motherboard Replacement, done: step 14, image 1 of 1
    • You are done - the keyboard is not connected to the laptop any more and can be replaced.
  15. Lenovo Thinkpad x230 Motherboard Replacement, Screen Module: step 15, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Screen Module: step 15, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement, Screen Module: step 15, image 3 of 3
    • Remove five 5.7mm screws from the bottom.
  16. Lenovo Thinkpad x230 Motherboard Replacement: step 16, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement: step 16, image 2 of 2
    • Unscrew two 5.7mm screws from the top of the bottom of the laptop.
  17. Lenovo Thinkpad x230 Motherboard Replacement: step 17, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement: step 17, image 2 of 2
    • Pull the palm rest off the laptop board.
  18. Lenovo Thinkpad x230 Motherboard Replacement: step 18, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement: step 18, image 2 of 2
    • Unlock the white seal and disconnect the blue cable.
  19. Lenovo Thinkpad x230 Motherboard Replacement: step 19, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement: step 19, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement: step 19, image 3 of 3
    • Carefully disconnect blue and red cables and remove them from plastic case.
  20. Lenovo Thinkpad x230 Motherboard Replacement: step 20, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement: step 20, image 2 of 2
    • Unlock white seal and diconnect blue cable from upper corner.
  21. Lenovo Thinkpad x230 Motherboard Replacement: step 21, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement: step 21, image 2 of 2
    • Remove two 4.1mm screws from the black frame.
  22. Lenovo Thinkpad x230 Motherboard Replacement: step 22, image 1 of 3 Lenovo Thinkpad x230 Motherboard Replacement: step 22, image 2 of 3 Lenovo Thinkpad x230 Motherboard Replacement: step 22, image 3 of 3
    • Carefully pull off black frame from laptop board.
  23. Lenovo Thinkpad x230 Motherboard Replacement: step 23, image 1 of 1
    • Carefully lift the screen module straight up to detach from board.
  24. Lenovo Thinkpad x230 Motherboard Replacement, Motherboard: step 24, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement, Motherboard: step 24, image 2 of 2
    • Remove a total of twenty-three 4.1mm screws from around the black plastic in the board.
  25. Lenovo Thinkpad x230 Motherboard Replacement: step 25, image 1 of 1
    • Disconnect black and red wires from bottom right corner.
  26. Lenovo Thinkpad x230 Motherboard Replacement: step 26, image 1 of 2 Lenovo Thinkpad x230 Motherboard Replacement: step 26, image 2 of 2
    • Carefully detach the motherboard (black plastic) from the laptop.
16 other people completed this guide.
Lino Virgen
975 Reputation
3 Guides authored
Texas Tech, Team 6-3, Bennett Fall 2016 Member of Texas Tech, Team 6-3, Bennett Fall 2016
TTU-BENNETT-F16S6G3
4 Members
3 Guides authored
6 Comments
is the cpu replaceable on one of these, or its soldered to the mobo? I want some laptop from the X- series wich will be able to handle an i7 (best if x230 as it is the newest i can afford)
Marcin - Reply
The X230 CPU is soldered to the board. i7 not really worth it because the performance difference is about +5% and battery life is poor compared to the i5 X230.
Marshall Richards -
i am using lenovo x230, when i press the power button not show screen POST Bios (Blank Screen) but the power button and the flash light on. What is my x230 problem ? htttp://www.designstrusted.com
hanif.fuqoha - Reply
Great walk-through.
I used this for my x220, which was identical apart from three minor differences.
Many thanks.
chris.r - Reply
Really clear document, better to use than Youtube videos.
Koulutus5 Terasoft - Reply
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 133
All Time: 23,053
