Lenovo Touch Y70-70 Hard Drive Replacement
  1. Lenovo Touch Y70-70 Hard Drive Replacement, Back Cover: step 1, image 1 of 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 Hard Drive Replacement: step 2, image 1 of 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Use the Phillips #0 screwdriver to unscrew the four screws.
  4. Lenovo Touch Y70-70 Hard Drive Replacement: step 4, image 1 of 1
    • Disconnect the hard drive from the motherboard.
  5. Lenovo Touch Y70-70 Hard Drive Replacement: step 5, image 1 of 1
    • Use the Phillips #0 screwdriver to unscrew the four screws on the sides of the hard drive frame.
    • Remove the hard drive from the frame.
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 2,587
