Lenovo X200 Memory Replacement
  1. Lenovo X200 Memory Replacement, Memory: step 1, image 1 of 1
    • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
  2. Lenovo X200 Memory Replacement: step 2, image 1 of 1
    • 2. Remove the panel to access the memory modules.
  3. Lenovo X200 Memory Replacement: step 3, image 1 of 1
    • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
    • Insert the notched end of the DIMM into the socket.
    • Press the DIMM firmly, and pivot it until it snaps into the place.
    • Make sure that it is firmly fixed in the slot and does not move easily.
4 other people completed this guide.
James Finch
2,424 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 32
All Time: 1,692
