Lenovo Y410P Hard Drive/SSD Replacement
  1. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Bottom Panel: step 1, image 1 of 2 Lenovo Y410P Hard Drive/SSD Replacement, Removal of Bottom Panel: step 1, image 2 of 2
    • Remove the eight M2.5x8mm Phillips head screws that fasten the bottom cover.
    • For the Lenovo Y510P, there's another screw in the center that has to be removed.
    • Lift bottom cover off and set aside.
    • On the Lenovo Y510P, use a black spudger around the outside edge to pop loose the bottom panel.
  2. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Hard Drive: step 2, image 1 of 2 Lenovo Y410P Hard Drive/SSD Replacement, Removal of Hard Drive: step 2, image 2 of 2
    • If you intend to reuse this Hard Drive/SSD, be careful with the removal. Hard impact may result in damage.
    • First remove the two screws at the end of the Hard Drive bracket then slide the Hard Drive/SSD out of its seat.
7 other people completed this guide.
Brandon
527 Reputation
2 Guides authored
Cal Poly, Team 21-21, Maness Winter 2015 Member of Cal Poly, Team 21-21, Maness Winter 2015
CPSU-MANESS-W15S21G21
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 8,531
