Lenovo Y520-15IKBN Display Replacement
  1. Lenovo Y520-15IKBN Display Replacement, Battery: step 1, image 1 of 2 Lenovo Y520-15IKBN Display Replacement, Battery: step 1, image 2 of 2
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  2. Lenovo Y520-15IKBN Display Replacement: step 2, image 1 of 2 Lenovo Y520-15IKBN Display Replacement: step 2, image 2 of 2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  3. Lenovo Y520-15IKBN Display Replacement: step 3, image 1 of 1
    • Lift the battery up and out of the chassis.
  4. Lenovo Y520-15IKBN Display Replacement, Display: step 4, image 1 of 1
    • Use an opening tool to pry off the display bezel.
  5. Lenovo Y520-15IKBN Display Replacement: step 5, image 1 of 1
    • Remove the four 4 mm screws with a Phillips #1 screwdriver.
  6. Lenovo Y520-15IKBN Display Replacement: step 6, image 1 of 1
    • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
    • Remove the display from the computer.
Mark A Clement
97 Reputation
1 Guide authored
Comm 260 Team 15 Member of Comm 260 Team 15
Community
1 Member
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 47
All Time: 1,628
